Crank Angle Sensor
Old Jun 29, 2004 | 07:25 AM
todb84's Avatar
1st timmer
todb84 is an unknown quantity at this point
Default Crank Angle Sensor
does anyone know where the crank angle sensor is on a 90 accord? if so how do i replace it?
Old Jun 29, 2004 | 12:14 PM
todb84's Avatar
1st timmer
Default Re: Crank Angle Sensor
Does Anyone Know?
mnchvgs79's Avatar
Custom User Title
mnchvgs79 is an unknown quantity at this point
I would venture to say low on the motor, somewhere in the center.
Old Jun 29, 2004 | 12:17 PM
todb84's Avatar
1st timmer
Ok Thanks But I Need To Know Where Exactly. The Haynes Manual Says It's Part Of The Distibutor Assembly But The Book Is For A 90-93 And The 93's Are Different And My Friend Said That The Book's Quote Is For The 92-93's So I Need To Know Where It's At On My 90.
Old Jun 29, 2004 | 12:25 PM
HatefulMechanic's Avatar
The Pro to call.
its in the dist.....
just save yourself the time and get another dist....either a good reman unit or a new one. believe me.....you will thank yourself for doing that.....
Old Jun 29, 2004 | 12:28 PM
kevdog_09's Avatar
WHO ELSE BOWLS?
kevdog_09 is an unknown quantity at this point
its part of the lower sub assy for the dist. hope this helps
Old Jun 29, 2004 | 12:40 PM
todb84's Avatar
1st timmer
yeah well i forgot to say that i have already replaced my distributor with a brand new one. btw-270 bucks
Old Jun 29, 2004 | 12:41 PM
todb84's Avatar
1st timmer
Old Jun 29, 2004 | 12:46 PM
The Pro to call.
ok, you asked where it was, and how to change it...
then you ask for more help?
what more do you want to know? i assume you are asking this because you are getting a CAS code?
more info would be helpful to those that try to help ya
and i have installed a few reman units (mainly cardone) that were bad out of the box....
backprobe the connector and check the output of the CAS with a digital labscope.....that way you can see if it has a shitty pattern, or if it doenst have the correct sweep, etc.....
Old Jun 29, 2004 | 12:52 PM
Crate's Avatar
poop
Crate Crate Crate Crate Crate Crate Crate Crate Crate Crate Crate
haha he didnt know where it was or how to replace it... ya think he's gonna have a labscope laying around? =]
