code 9 on mini me what can cause it? Chamaro and others help
98 civic with mini me d16z6 head and d16y7 engine block with d16y8 timing belt. I put on the bunked distributor then i bought a new distributor. same code 9. What else can throw the code? zex stage 2 cam shaft installed.
Has anyone had this problem with basically about the same set up ofr similar on their mini me?
please help.
please help.
corona connessuer
Re: code 9 on mini me what can cause it? Chamaro and others help
please help.
please help.
Re: code 9 on mini me what can cause it? Chahonda and others help
I was using a p28 but it is bunked throwing a code 14 barometric sensor with my vafc. Then I changed my ecu to a p06 code 14 went away just it is a bit slower because of the less aggresive fuel map, ofcoarse no v-tec but eh, not like I use it so much, anyway.
My d16z6 cylinder head is built up, comp cam stage 2, valve lapped, p+p on eshaust and intake, cleaned out chambers,valve springs and titanium retainers, new oil seals.
I would like to use a y8 head but still will need another distributor and more money is wasted. I am not sure if the obd 2 distributor would go with the majority of the obd1 sensors, either.
I am going to be bringing my car to next level next week to get some work on it. I am having the timing belt re-done then I am thinking that when I pull out my crank angle fluctuation sensor(obd2) it should take care of the problem since it should be fighting with my CKF sensor built into the distributor (obd1)
I will let you guys know how my theory goes.
Die reinste Bösen.
you spent all that money on the headwork and your not even going to use vtec? gee whizz. id get it fixed all on a p28...otherwise your wasting more then just the money for the distributor.
