code 9 on mini me what can cause it? Chamaro and others help
98 civic with mini me d16z6 head and d16y7 engine block with d16y8 timing belt. I put on the bunked distributor then i bought a new distributor. same code 9. What else can throw the code? zex stage 2 cam shaft installed.
Has anyone had this problem with basically about the same set up ofr similar on their mini me? please help. |
Re: code 9 on mini me what can cause it? Chamaro and others help
Re: code 9 on mini me what can cause it? Chahonda and others help
I was using a p28 but it is bunked throwing a code 14 barometric sensor with my vafc. Then I changed my ecu to a p06 code 14 went away just it is a bit slower because of the less aggresive fuel map, ofcoarse no v-tec but eh, not like I use it so much, anyway.
My d16z6 cylinder head is built up, comp cam stage 2, valve lapped, p+p on eshaust and intake, cleaned out chambers,valve springs and titanium retainers, new oil seals. I would like to use a y8 head but still will need another distributor and more money is wasted. I am not sure if the obd 2 distributor would go with the majority of the obd1 sensors, either. I am going to be bringing my car to next level next week to get some work on it. I am having the timing belt re-done then I am thinking that when I pull out my crank angle fluctuation sensor(obd2) it should take care of the problem since it should be fighting with my CKF sensor built into the distributor (obd1) I will let you guys know how my theory goes. |
you spent all that money on the headwork and your not even going to use vtec? gee whizz. id get it fixed all on a p28...otherwise your wasting more then just the money for the distributor.
