"Click" sound and my car won't start...
Old Jun 13, 2007 | 02:10 PM
HEISENBERG's Avatar
БЛЯДЬ!
HEISENBERG HEISENBERG HEISENBERG HEISENBERG HEISENBERG HEISENBERG HEISENBERG HEISENBERG HEISENBERG HEISENBERG HEISENBERG
Default "Click" sound and my car won't start...
Like the title says. I already changed the starter thinking that was the problem but nothing. The car will start sometimes because I drive it everyday but sometimes it just starts to act up and all you hear is a "click" sound and nothing. Radio, lights, etc work fine. Any suggestions?
BTW is a 98 B18C5.
Thanx guys.
Old Jun 13, 2007 | 02:35 PM
MerF's Avatar
Ghost
Default Re: "Click" sound and my car won't start...
Battery or loose connection to the battery. Best way to know is when the car is making the click, turn the headlights on and try to start it. If the lights go out when it's clicking, there's something loose, usually it's corrocion on the ground terminal. Poor some Coke on it for a quick cleaning, and tighten it down. If the posts are tight and clean already have Advanced Autoparts or Autozone run a free diagnostic on your charging system. It's free and pretty much tells the tale every time.
good luck.
Old Jun 13, 2007 | 06:10 PM
krazdracer's Avatar
krazdracer has disabled reputation
good luck.
there it goes +1 sounds like a dead battery because the radio and stuff works...see if the connection on the starer is loose.
Old Jun 13, 2007 | 06:11 PM
Jarrod's Avatar
braap braap
Like others suggested, check the connections on the battery.
Also check the ground for the transmission. Sometimes if its loose this will happen.
Old Jun 13, 2007 | 06:19 PM
Hondas_Only's Avatar
Do You Want More?
Hondas_Only Hondas_Only Hondas_Only Hondas_Only Hondas_Only Hondas_Only
i have the exact same drama with my accord... only on hot days when the engine is really hot... i get out... wiggle the battery wires and bingo! back in bidnez!!
Old Jun 13, 2007 | 10:31 PM
HEISENBERG's Avatar
БЛЯДЬ!
Thanx guys. I'll try that and see what happens. Hopefully is something like that and I won't have to spend a lot of money.
Old Jun 14, 2007 | 02:09 AM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
if your having problems when its really hot outside it can also be your main relay acting up, pretty frequent problem on hondas when its hot out.
Old Jun 14, 2007 | 04:54 AM
nthn Specl's Avatar
nthn Specl is an unknown quantity at this point
I'm having this exact same problem with my Tacoma. I haven't been able to figure out what factors make it not start (hot day, etc) or what makes it start when it finally does. I cleaned off the battery terminals and tightened everything down. It's very intermittent. I was going to start by replacing the Starter and go from there.
Old Jun 14, 2007 | 05:30 AM
HEISENBERG's Avatar
БЛЯДЬ!
Not to sound stupid but where the hell is that?
Thx
Old Jun 14, 2007 | 05:46 AM
CHAHONDA's Avatar
corona connessuer
Thx
thats highly unlikey that its the problem. when the main realy goes bad the car will crank fine but wont start due to the fuel pump not being energized. you my friend have either a ground problem or a faulty battery cable connection. or a combination of both
