check engine codes
Old Oct 11, 2006 | 02:27 PM
driveitright's Avatar
driveitright has a reputation beyond reputedriveitright has a reputation beyond reputedriveitright has a reputation beyond reputedriveitright has a reputation beyond reputedriveitright has a reputation beyond reputedriveitright has a reputation beyond reputedriveitright has a reputation beyond reputedriveitright has a reputation beyond reputedriveitright has a reputation beyond repute
Default check engine codes
I need some help with checking my engine codes, I know where to look and have removed the panel to see where my ecu is but i'm not sure what to do from here? I drive a 95 civic ex with a d15b swap any help is appreciated!
Old Oct 11, 2006 | 02:50 PM
MajorsEF's Avatar
MajorsEF will become famous soon enough
Default Re: check engine codes
well i have a d15b7 in my 89 hatch but its all obd1, i have 2 wires coming off my jumper harness that i touch that are blue and purple
Old Oct 11, 2006 | 02:53 PM
MajorsEF's Avatar
go under the glove box there is a green plug with 2 gray plugs, get the one with 2 wires in it and bridge them together and start counting the blinks
Old Oct 11, 2006 | 06:51 PM
ok codes are:
14 - iac valve
41 - o2 sensor
I'm thinking the o2 senser is making the iac valve code come up so it's just a bad sensor.
My question to everyone is how urgent is this to fix, and what risks am i taking by driving it.
Old Oct 12, 2006 | 07:58 AM
MajorsEF's Avatar
well my 41 wont go away it go like water in the plug, i dried it out and everything car runs perfect but the code wont go away, and im not losing gas milage
Old Oct 13, 2006 | 08:22 AM
mike nagz's Avatar
da dragva kokopelli
how do you check in a 94 integra? sorry to thread jack.
Old Oct 13, 2006 | 08:52 AM
94 Teg should be the same, can anyone verify?
If the code is still there, I'm guessing you still have a problem. Unlike OBD2 ECUs (which store codes in memory), OBD1 ECUs will not display a code once it has been fixed. So you either have a problem with the O2 sensor, or you've damaged the ECU because of the water. It's also possible you still have some water somewhere. The ECU will display a fault if it detects too much current being output from it's current source for the O2 sensor, so you may still have a water-related problem.
Is the IACV code still there?
Old Oct 13, 2006 | 08:23 PM
MajorsEF's Avatar
i dont think he got water in his i got water in mine
MajorsEF's Avatar
oh yea 94 integra do what i told him
jdmb16hatch
Nov 11, 2008 03:08 PM
jimporsche86
Apr 1, 2004 03:53 PM
NRG_RSX
Mar 18, 2004 06:11 PM
RedRexSI
Feb 21, 2004 08:06 AM
CRXtacy
May 15, 2003 07:31 PM
