Engine throwing codes 17 and 20
Old Feb 19, 2004 | 05:11 PM
RedRexSI's Avatar
RedRexSI RedRexSI RedRexSI RedRexSI RedRexSI RedRexSI RedRexSI RedRexSI
Question Engine throwing codes 17 and 20
17 = Vehicle speed sensor
20 = electric load
I know my speedo cable isnt hooked up so that takes care of 17 but what does 20 mean? Electric Load? someone help me out
Old Feb 19, 2004 | 11:46 PM
StpH8n's Avatar
StpH8n is an unknown quantity at this point
Default Re: Engine throwing codes 17 and 20
ELD can be a number of different things. Make sure ALL three of your grounds are good (tranny, valve cover, and thermo). If all these are good make sure all of your connectors are connected to the correct spots. I had a problem where i had ECT A (switch on thermo) hooked up on ECT B (switch on block) and vise versa. Caused me to throw code 20 until i switched them back.
If all your grounds and connections are good, then your next move should be to check all your wiring. Make sure there are no bare wires touching anything. And if after all that you are still showing a code 20. You could also try and reset your ecu (unplug then plug it in again), that may clear it up.
Old Feb 20, 2004 | 10:55 AM
RedRexSI's Avatar
Thanks alot i did what you said and it is fine now and yes i will 'STOP HATIN'
Old Feb 21, 2004 | 08:06 AM
StpH8n's Avatar
Cool deal. Glad i could help.
c1turbo
Jan 30, 2007 03:05 PM
Sidewinder20
May 11, 2006 10:10 AM
PRO-Habit
Aug 28, 2004 09:06 AM
PRO-Habit
Jul 21, 2004 03:54 PM
NRG_RSX
Mar 18, 2004 06:11 PM
