CEL - 89 b16 hatch
Old May 11, 2006 | 11:27 AM
b18cwon's Avatar
b18cwon has a reputation beyond reputeb18cwon has a reputation beyond reputeb18cwon has a reputation beyond reputeb18cwon has a reputation beyond reputeb18cwon has a reputation beyond reputeb18cwon has a reputation beyond reputeb18cwon has a reputation beyond reputeb18cwon has a reputation beyond repute
Default Re: CEL - 89 b16 hatch
any idea what they are ?
Old May 11, 2006 | 12:17 PM
b16 snatch's Avatar
Captain Deeeez Nutzz
b16 snatch has disabled reputation
http://hondachat.com/archive/index.php/t-108.html
took 45 seconds to find on a google search
Old May 11, 2006 | 01:36 PM
SlowLS's Avatar
Sumospeed #O.G.
sounds like you need to replace the tps. coolant sensor will not cause the car to fall on its face or anything.
Old May 11, 2006 | 01:49 PM
b18cwon's Avatar
i called around for a tps and found it only at the dealer ...dealer told me that its apart of the throtle body and will cost me 600 bucks. for the whole unit. .......anyway around that ?
Old May 11, 2006 | 01:58 PM
SlowLS's Avatar
Sumospeed #O.G.
pm'd you back on how to get around that.
Old May 13, 2006 | 06:06 AM
lsvtecSCbeast's Avatar
lsvtecSCbeast has disabled reputation
depending on which coolant sensor it is it will make ure car run like ass and it will not let vtec hit!because it cant read how hot ure motor is so it goes into safe mode.I know because ive had the same prob.And also u can use a tps from any b or d series motor so go to the junk yard and get a throttle body because u r going to have to drill the sensor off of the throttle body and get new bolts for it.Well let me know how it comes out!
Old May 13, 2006 | 06:52 AM
j4k3's Avatar
holla
Go to the junk yard and pick up an old throttle body then grind the tps off of it and your old one then screw it in. You might have to go through a couple to get it right.
Old May 13, 2006 | 08:05 AM
b16 snatch's Avatar
i have read that a tps needs to be calibrated. anyway around this without special tools?
88CRXHFBSTNG
Jul 25, 2005 07:40 AM
94 Teggy
Dec 27, 2004 09:36 AM
94 Teggy
Oct 19, 2004 09:42 AM
