Carb Problem
Old Feb 18, 2003 | 06:02 PM
SlidingS-10's Avatar
SlidingS-10 is an unknown quantity at this point
Angry Carb Problem
well lets see i got a 355 miled built sbc in my truck and i had a 750 on it...duell feed well i swiched the duell feed boles onto a 650 for gass milage and the 750 was over kill.... well now im geting a hess if i nail the gass it will die.... only in gear ... but if i eas it then nail it it dus fine.. could the accelarater pump be set to tight or what else could couse this ... its on a holley
Old Feb 19, 2003 | 05:20 PM
Old Feb 20, 2003 | 03:15 AM
marshall's Avatar
marshall has disabled reputation
If the 750 is too much, put a 650 on. Don't mix and match...
Old Feb 20, 2003 | 04:32 AM
ToyotaTechGeek's Avatar
brake/steer/throttle
well, if it's a 'bog' when you nail it, then it's probably too much fuel. what you can do is try to replicate it and allow it to stall, get out and pull a plug. if it's wet as hell, then you have your answer. btw: is this a manual or autotragic trans? you can also play a bit with timing and a bit more ignition, but i think it sounds like you're a bit over-carbed.
Old Feb 20, 2003 | 07:07 AM
how can i go down 2 a 650 and be over carbed i took the 750 off ... my motor took every bit the 750 could through at it it was just 2 much gass money ....
WutupYo
Mar 3, 2009 08:14 AM
alcfourlife
Dec 31, 2008 04:38 AM
outlaw122504
Sep 5, 2008 06:49 PM
s2k7
Jul 30, 2004 01:32 PM
