brake problem...can anyone help?
Old Apr 19, 2006 | 08:16 AM
aacjohnc's Avatar
Default Re: brake problem...can anyone help?
did you bleed the brake ? front left to back right and front right to back left ? my 91 explorer did the same thing until i went back and bleed them. it should help. did you compressed the caliper out all the way when you changed the bakes cause if you dont then it will be a tight fit and the brakes will stick to the rotors which will cause them to warp the roto and your pads to go bad . this should help .oh and by the way make sure the line going to the caliper is not twisted.
Old Apr 19, 2006 | 02:56 PM
hondapride6909's Avatar
hondapride6909 is an unknown quantity at this point
thanks man ill give it a shot. i havent had a change to go work on the brakes but ill get back at yall when i do get a chance later
jermzkill
Jul 5, 2007 02:49 PM
p-stone
Jun 13, 2007 12:05 PM
92_SR20
Nov 6, 2006 12:46 PM
The Barst
Sep 11, 2005 08:13 AM
00CivicGirl
Jun 16, 2004 10:37 AM
