brake light issues
Old Jun 25, 2007 | 01:36 PM
spidsta's Avatar
i see you! ಠ_ಠ
spidsta spidsta spidsta spidsta spidsta spidsta spidsta spidsta spidsta spidsta spidsta
Default brake light issues
My 3rd brake light stays on, even when the key is out and the car is empty. Though when i step on the brake, the other 2 brake lights do NOT work at all. Im stumped. i've checked my fuses but I have not checked the brake light switch. I will once i'm out of work.
since the 3rd light will not shut off, it has completely drained my battery.
i am terrible with car electronics so does anyone have any suggestions on what to do?
Old Jun 25, 2007 | 02:17 PM
Computer_Nerd's Avatar
superuser
Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd
Default Re: brake light issues
Sounds like there is a short in the bulb for the 3rd brake light, check that one first. The brake lights don't need the key in the ignition.
Old Jun 26, 2007 | 03:38 AM
HatefulMechanic's Avatar
The Pro to call.
GM? if so, get a new switch, and then check to see if the rear bulbs are blown out. the switches on them have two outputs, one for the CHMSL and one for the rear lights.
if its a VW....its under recall.
if its a ford, i can honestly say i havent seen a switch fail, but the M/C bushings do get worn causing that problem.
if its a honda, make sure that the rubber bumper on the brake pedal shaft is still there, most likely it dry rotted and fell out, leaving the plunger in the brake light switch stuck out.
Old Jun 26, 2007 | 05:34 AM
spidsta's Avatar
i see you! ಠ_ಠ
right on the nose. it took me a while to figure out that shit was missing.
Old Jun 26, 2007 | 07:33 AM
The Pro to call.
seen it many times. i have a set of the rubber bumpers in my toolbox for that reason only!
Kris.Is.Foamin
May 19, 2010 09:30 PM
jdmsijdm
Jan 26, 2009 03:13 PM
jdmcoupe93
Sep 6, 2007 08:15 PM
Cobra4B
Mar 11, 2007 11:05 AM
