BOV sounds weird?
Old Oct 12, 2005 | 12:47 PM
VanillaThrilla's Avatar
wub wub wub wub
Default Re: BOV sounds weird?
I'll take it if you're selling it cheap
Old Oct 14, 2005 | 06:29 AM
higB_0x05's Avatar
higB_0x05 has disabled reputation
I don't know the details on that particular bov but most will start to make a studder sound in time. They need regular disassembly, cleaning (with a de-greaser), and lubrication (I use white lithium grease.
but only 5 psi? yeah I would think you would need a very lightweight spring in that to work properly.
Old Oct 14, 2005 | 08:33 AM
Silverbullet86's Avatar
Silverbullet86 Silverbullet86 Silverbullet86 Silverbullet86 Silverbullet86 Silverbullet86 Silverbullet86 Silverbullet86 Silverbullet86 Silverbullet86 Silverbullet86
im really convinced you have the vacuum line hooked up wrong and your getting surge lol. Either that or your BOV is down all the way tight.
Old Oct 14, 2005 | 11:04 AM
ProbeGT-ZE's Avatar
I <3 Hikki Chan!
ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE
the ssqv requires about 7psi on a piston engine and 9psi on a rotary to function normally, i didnt make enough boost to open the valve
Old Oct 16, 2005 | 08:34 AM
minboostS13's Avatar
midnight motorsports
minboostS13 has disabled reputation
that sucks, trade it for a greddy type s or RS. Those fuckers open at 2psi.
Old Oct 16, 2005 | 08:36 AM
wub wub wub wub
they don't close all the way at idle.. or at least the type-s.
Old Oct 16, 2005 | 08:42 AM
Ive been screwing with mine (Type S) for awhile...it doesnt open and leak at idle, it doesnt leak at low boost, but itll open when shifting at low low boost. So low my boost guage isnt even reading it. @ hi boost, itll leak if not adjusted right. But the again, i have a BOV sound coming from my intake when i shift. TWO sounds...BOV and intake.
Old Oct 16, 2005 | 10:20 AM
ProbeGT-ZE's Avatar
I <3 Hikki Chan!
yeah i've got one coming...the type-s is annoying as hell but the way i have my stock BOV set up right now, it leaks a lot worse than a type-s (my stock bov doesn't stay shut at all, it creates a HUGE vaccuum leak if vented to atmosphere, so i used a swing valve (brass from home depot) on the end of it to keep it shut, but because the swing valve isn't air tight im losing some boost through there) either way, the type-s should be good for me since im not going to be making more than 10psi max anyway
Old Oct 16, 2005 | 12:17 PM
BzTypeR's Avatar
04 M3
BzTypeR is an unknown quantity at this point
Should have got the Type-RS i got the it 1st day it came out for my GSX around last winter or sumtime...i liked it alot i was runnin 23 pounds no leaks ever
Old Oct 16, 2005 | 01:43 PM
Brian T's Avatar
Kicking Ass
Brian T Brian T Brian T Brian T Brian T Brian T
Most cars will have a bit of compressor surge at low boost. It's not that big of a deal. It's high boost that you want to try to eliminate that if you're trying to preserve your turbo.
Celicagurlva
Dec 30, 2003 06:27 PM
05DC5
Apr 18, 2003 01:17 PM
