Boost Question
Old Nov 18, 2002 | 05:02 PM
itsaqwik1's Avatar
Omerta
itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1 itsaqwik1
the aplication for our car is rite around $1300 ... for install , test and tune ... so....
it might be a different set up ... but im pretty sure thats what it is .. but i might be wrong though ....
Old Nov 18, 2002 | 05:03 PM
Blasphemous's Avatar
Former 757'er
Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous
The price for a Haltech is about $1300, Haltech and all accesories for ANY car. Add another $400 (at least) for the 720cc injectors and there's NO tuning or install added in yet.
Old Nov 18, 2002 | 05:04 PM
itsaqwik1's Avatar
Omerta
... that may be where i screwed up ... thanks... but i do know that it included tuning
Old Nov 18, 2002 | 05:07 PM
Former 757'er
That's for an E6K, since the E11 just came out, they should start dropping.
Old Nov 18, 2002 | 06:37 PM
Heat's Avatar
HAM
Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat
I'm well aware of this, but it doesn't address the question he asked. How much psi he can safely run. I was addressing some information that he needs to find out, or he needs to provide to take a step farther.
I don't know why you directed this post towards me.
Originally posted by 385LT1
ah, but engine size does.....
a small turbo may be capable of spinning up 30psi... but not on a larger cid engine....
a small turbo on a larger engine may be capable of only 4psi, where it was capable of 15psi on a smaller engine...
also, keeping in mind.... cnc'ing the heads, bigger valves, camshaft duration and overlap, low restriction exhaust system
all play a role in just how much boost you will see....
2cents........
Old Nov 18, 2002 | 06:46 PM
385LT1's Avatar
A.P.E.
385LT1 is an unknown quantity at this point
i was adding info to your post, i didnt answer his question simpy because you were the first one to respond,
no need to step on anyones toes...
91fastback
Aug 13, 2008 07:32 AM
tinytim
Aug 12, 2008 06:30 AM
eksleeper
Jun 27, 2005 02:54 AM
eksleeper
Jun 21, 2005 08:26 AM
BlackSRT4
May 10, 2004 08:11 PM
