Boost Leak MK4 1.8t
Old Jan 14, 2007 | 04:00 PM
DonVizMe's Avatar
green box is back!
DonVizMe has much to be proud ofDonVizMe has much to be proud ofDonVizMe has much to be proud ofDonVizMe has much to be proud ofDonVizMe has much to be proud ofDonVizMe has much to be proud ofDonVizMe has much to be proud ofDonVizMe has much to be proud ofDonVizMe has much to be proud ofDonVizMe has much to be proud ofDonVizMe has much to be proud of
Default Re: Boost Leak MK4 1.8t
Anyother suggestions?
Old Jan 14, 2007 | 06:14 PM
VanillaThrilla's Avatar
wub wub wub wub
The Bailey DV's are typically good but if it's a diaphram diverter valve, the diaphram may need to be replaced. Is it a piston valve, or diaphram? Change the diverter valve if you have another you can try out. Even if it's a piston valve, if the valve doesn't close all the way, it will cause a leak.
Old Jan 16, 2007 | 10:21 AM
DonVizMe's Avatar
green box is back!
Well bailey uses the piston type, and the only other DV i have is the stock one. And that will be hard to use as a guage as well because it will release too soon.
Old Jan 16, 2007 | 10:39 AM
Verbal's Avatar
r0tard
Verbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these parts
Well, on my FD (which had miles of vacuum hose) i would.....
Start car, let idle.
Spray little bursts of ether any where i thought there "MAY" be a leak.
If you find the leak, idle will rise...
This method is tired and true, just watch your paint, (and your exhaust...lol)
Good luck, vacuum leaks can be a motherfucker!
vinniebeachbum
Jun 23, 2006 01:58 PM
"SI"ngle Cam
Apr 27, 2005 06:10 PM
"SI"ngle Cam
Apr 20, 2005 05:34 PM
Runnin13s
Jul 24, 2004 08:01 PM
quikeclipse
Feb 26, 2003 07:02 AM
