b20 ek won't start? HELP!!!!!
Got spArk and fuel just won't start. I just replaced my ls for a b20 I'm using everything off the ls like dizzy fuel rail and injectors. Car is obd2 with a p75 all help is wanted.
peaches
Re: b20 ek won't start? HELP!!!!!
just wont start? what IS it doing then? any starter noise? is it trying to turn? is your battery ran factory or in the trunk (if in trunk check for a inline fuse or distribution block)...recheck all your grounds too
If you've swapped everything over you've either damaged something or installed something wrong. I'd look really carefully at the distributor timing and the order of the spark plug wires. Most other things you should give you a CEL if the ECU decides there is a no-start condition.
93civiccpe
01-28-2005 03:26 AM
