B18 Questions
Originally Posted by ps90lsturbo
close hp and tq give it good burn-out ability, with out roasting your clutch too much.
this quote is what i was referring to...Thats one of the dumbest things I've ever heard..I'm sure other people will think the same. But thanks for making it easy on me though man
I dont even have to clap back, you've already made yourself look dumb as fuck. so holla when you get back bambam...
you want it you got it, i get back to va on tues. me and my teg will meet you any where. don't worry about my wallet, it won't get hurt. also if you knew anything about b18's you would know that the b18a and the b18b are the same motor with different compression, the b18b making the hp jump with compression. so in fact you would save money by buying the b18a and doing the build on it than the b18b. do you know the other differences in the motor other than hp/tq.
b18b has a better flowing head. n the compression on both is 9.2:1. only difference is the cams, intake, and exhaust manifold.
you can get the b18a obd0 for your rex or get the b18b which as obd1 but you will have to get and obd0 to obd1 harness unless u do the wiring yourself. you can use a b18a cable tranny on both engines.
Originally Posted by CRXalwysk8
soooo... after this fighting, should i get a b18a or b for my rex? is it a big deal to switch tranny's ( to hydro) and to obd1?
obd1 b18b
