stripped tensioner bolt... help!
Old Jul 27, 2004 | 08:08 AM
TPJ's Avatar
TPJ
sumospeedDOTcom
TPJ is a jewel in the roughTPJ is a jewel in the roughTPJ is a jewel in the roughTPJ is a jewel in the roughTPJ is a jewel in the rough
Default stripped tensioner bolt... help!
anyone have the slightest clue what way to go about getting this off? i fainally got off my ass to finish getting my car running since my friend just bought it off me, and all i have left is to replace the tensioner and put the timing belt back on, HOWEVER, the bolt on the old tensioner is stripped all to hell from whoever did work on it last ( a friend of mine ). so now i have this problem and have no clue how to go about it. the motor is a b16 in a crx, so theres only about 4 inches between the bolt and the fender well.
Old Jul 27, 2004 | 11:38 AM
TPJ's Avatar
TPJ
sumospeedDOTcom
Default Re: stripped tensioner bolt... help!
Old Jul 27, 2004 | 03:03 PM
NIC668's Avatar
Stripped head?
Old Jul 27, 2004 | 03:26 PM
g S x's Avatar
RIP Chris Schader
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
vice grips
or a chisel with a hammer to try and turn it loose
Old Jul 27, 2004 | 04:03 PM
fatboyee's Avatar
yea, i'm that guy
fatboyee has disabled reputation
if you're not concerned with saving the tensioner...
take a sawzall to the head of the bolt until it is cut completly flush. pull off the tensioner pulley, and use a GOOD set of vicegrips to remove...
or take it to a machine shop
Old Jul 27, 2004 | 04:13 PM
sk8rmike's Avatar
Bitches get Stitches
sears has a socket set for grabbing stripped bolt heads. works really really well. go there and ask for it. they look like sockets with twisted teeth inside them that are sharp to grab the head of the bolt. they work very well. i've had to use them on occasion.
Old Jul 27, 2004 | 05:57 PM
VT Prix GT 2006's Avatar
Motor Trend Mechanic
VT Prix GT 2006 is an unknown quantity at this point
I use an impact wrench to eventually get the tensioner bolt off. They do sell pulley removal kits to make this kinda thing a breeze.
Old Jul 27, 2004 | 06:14 PM
nickyroo's Avatar
you could take a grinder or cutting wheel and cut a slot into the bolt head, get a flathead screwdriver head for a ratchet and get it out that way, or use a left handed drill bit.
Old Jul 27, 2004 | 06:30 PM
sk8rmike's Avatar
there isnt enough room there for anything other than a socket wrench or wrench...
Old Jul 27, 2004 | 06:32 PM
Jester_Si's Avatar
Jungle Boogie
Jester_Si has disabled reputation
if memory serves me correct, its a 14mm bolt-
Try using a 13mm and tapping it on, i've had to use a dremel to shave bolts to make a smaller socket fit, but hell...it worked.
