amplifier help
Old Feb 12, 2007 | 07:13 PM
BuddyClubCivic's Avatar
All Motor All Day
BuddyClubCivic has disabled reputation
Default Re: amplifier help
Originally Posted by Pyscolilboy17
Yea atleast go with 4 guage and 8 guage for a negative cable.
If you go with 4 gauge power wire then the ground wire must be at least the same size as the power wire.
Old Feb 13, 2007 | 05:22 PM
greencoug's Avatar
Hannibal bitches
greencoug greencoug greencoug greencoug greencoug greencoug greencoug greencoug greencoug greencoug greencoug
Absolutely. I'm an electrician, this is absolutely right. Mixing the gauge is unsafe and could cause a fire.
Old Feb 13, 2007 | 09:23 PM
greekfreak's Avatar
HollyLeuia HollaBack
greekfreak greekfreak
mine is having the same problem, but the amp is not over heating. It turns on for maybe a millisecond, then just turns back off. hellpp!!
Old Feb 14, 2007 | 02:59 AM
xian's Avatar
xian is an unknown quantity at this point
What's the fuse rating on the amp?
Honestly, if you're running a single amp, you *should* be fine on an 8awg wire, unless you're pulling some serious current.
Make sure you've got a good clean ground going to the chasis, all the teminals and connections are clean, etc.
greekfreak - might be something with the remote turn-on wiring from the HU to the amp. That sounds like its sending a pluse instead of a constant 12vdc.
Old Feb 14, 2007 | 07:29 AM
EKcivic23's Avatar
Dutty Whine
EKcivic23 can only hope to improve
sounds like a short or a bad ground. check your fuses too
Old Feb 14, 2007 | 03:36 PM
pstevo247's Avatar
pstevo247 is an unknown quantity at this point
Originally Posted by 97_SI
my amp resets (turns off n then on) everytime when i turn my volume louder. does anyone know why this could be.
it could be a bad ground also man but yea usually its cause your amp has a protect on it and its stoping you from blowing your subs
ViPER1313
Aug 13, 2008 07:22 PM
97_SI
Mar 4, 2007 05:23 AM
