amplifier help
Old 02-12-2007, 08:09 AM
ïş 300
97_SI's Avatar
97_SI 97_SI 97_SI 97_SI 97_SI 97_SI 97_SI 97_SI 97_SI 97_SI 97_SI
Default amplifier help
my amp resets (turns off n then on) everytime when i turn my volume louder. does anyone know why this could be.
97_SI is offline
Old 02-12-2007, 08:33 AM
RandomTask's Avatar
Default Re: amplifier help
You're overdrawing / overloading on the amp so it has a built in protector.
RandomTask is offline
Old 02-12-2007, 08:36 AM
Pyscolilboy17's Avatar
Pyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud ofPyscolilboy17 has much to be proud of
well wat size battery cable do u have?
1 reason could be too small
another could be the amp is getting too hot and overloading and it cos's it to reset it self
that would be the main reasons
Pyscolilboy17 is offline
Old 02-12-2007, 09:29 AM
2lateJr.'s Avatar
2lateJr. is an unknown quantity at this point
Yeah, like they said. If your radio is turned up too loud, it overheats the amp causing it to shut off temporarily, so its good to have the amp at a place in the car where it will receive air for temp. control.
2lateJr. is offline
Old 02-12-2007, 11:12 AM
All Motor All Day
BuddyClubCivic's Avatar
BuddyClubCivic has disabled reputation
Also if your amp is not a class D amp you may be bridging your amp down to an ohm level it cannot support. So check to see what ohm subs you have.
BuddyClubCivic is offline
Old 02-12-2007, 03:37 PM
ïş 300
97_SI's Avatar
thnx, if its overheating, whats the solution. by the way i have a kicker amp 350.2 i have 8 guage cable for power. shud i change that power cable?
97_SI is offline
Old 02-12-2007, 03:47 PM
Do You Want More?
Hondas_Only's Avatar
Hondas_Only Hondas_Only Hondas_Only Hondas_Only Hondas_Only Hondas_Only
8 gauge... ouch... you need 4 gauge brother!
Hondas_Only is offline
Old 02-12-2007, 04:22 PM
corona connessuer
CHAHONDA's Avatar
yup! i had 0 gauge for my 3 amps
CHAHONDA is offline
Old 02-12-2007, 05:15 PM
OV-104
Atlantis's Avatar
My cd player does that
Atlantis is offline
Old 02-12-2007, 05:39 PM
Yea atleast go with 4 guage and 8 guage for a negative cable. You could try finding a little fan or something out of an old PS2 or something and rig it up so it cools your fan but sometimes that can be tricky.
Quick Reply: amplifier help
