99 GSX AVC-R plumbing and tuning. help!
I just bought a 99 gsx and (attempted to) install an Apex'i AVC-R electronic boost controller in it. I know i have the wiring right, all the guages etc.. seem to be working. But on the plumbing for the actuator i'm a little lost. I attempted it but I'm not positive that I did it right and my problem may be just in the tuning of it. So is there anyone out there that has installed one of these on a dsm before that could check my work and help me out with the tuning of it a little? Any help would be much appreciated.
Right now I have the vacume hose from the wastegate going into the [COM] Nipple on the actuator and a vacume hose going from the [NO] Nipple on the actuator to a nipple on the compressor housing on the turbo.
Sounds like the solinoid is hooked up properly. Did you remove the vaccume cap off the other port on the solinoid? If not do that, then if you are still having troubles it is most likley a tuning issue. If you need any more help PM me
Ya. I took the vacume cap off of the other port, I just have a nipple screwed into it with no hose. According to the diagram I think it is hooked up right. I just keep getting semi large boost readings, I'm running the stock turbo still but I think the highest reading I got with the avc-r hooked up was like 1.56 bar. I'm almost positive I have the pressure sensor hooked up right. I just t'd it off of a vaume line on the intake manny, and yes it is facing downward. I'm going to check all of my vacume lines and make sure I don't have any leaks... But I am thinking its more of a tuning thing.. I'll probably pm you later on for some help with that..
Also, when I adjust the boost and duty cycle it doesn't really seem to change the actual boost much, the peak boost is usually from 1.25 bar - 1.56 bar, regardless of what I set the boost for. The only thing that actually seems to make a noticable difference is when I adjust the duty cycle, it seems like it just changes how quickly the turbo spools.
SuperChargedZ
Want to Buy / Trade ARCHIVE
Sep 17, 2008 07:32 AM
SuperChargedZ
Dec 11, 2007 03:59 PM
