'98 Malibu Brake Problems
Old Oct 19, 2008 | 11:28 AM
92_SR20's Avatar
±RepLegion
92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20 92_SR20
Default '98 Malibu Brake Problems
So the ABS and Brake light on 98 Malibu have come on, I'm actually doing a little research as I type this. Aside from checking the wheel sensors to make sure they're connected and not visibly damaged any suggestions on what to do? I don't really feel like shelling out the money to a shop to tell me they can't do anything or I'll have to replace X hub for $400 + shop fees. Anywho, I'll be checking back here off and on, any help is appreciated.
Old Oct 19, 2008 | 11:43 AM
widebody91hatch's Avatar
widebody91hatch has disabled reputation
Default Re: '98 Malibu Brake Problems
i wouldn't think it would be a abs wheel sensors due to the fact that both the abs and brake lights are on.... if it is related it would be elsewhere in the system where the abs system and the brake system actually are tied together.... because wheel sensors only detect a reading from the abs rings on cv axles or hubs depending if its front or rear.... i would check relays and fuses, check brake fluid level, check parking brake switch.... basically check everything to make sure that they are tied into the same problem and not 2 seperate problems.... pm me if you find anything out.... and it doesn't take much damage at all to any of the abs rings to cause a bad reading
Old Oct 20, 2008 | 02:08 PM
92_SR20's Avatar
±RepLegion
Checked the fuses and brake fluid and they are all good. Now I'm off to play with the relays to see if they / that may be the problem.
69vette
Nov 24, 2008 01:20 PM
MORE IMPATIENT
Jul 10, 2008 03:16 PM
seltech
Jan 12, 2005 02:05 PM
pimpingreen13
Sep 11, 2004 03:33 AM
