ls/vtec///NEED HELP
Old Oct 9, 2008 | 05:06 PM
6_speedeg's Avatar
Lurking....
6_speedeg 6_speedeg 6_speedeg 6_speedeg 6_speedeg 6_speedeg 6_speedeg 6_speedeg 6_speedeg 6_speedeg 6_speedeg
Default ls/vtec///NEED HELP
fixed
Old Oct 9, 2008 | 07:05 PM
radiaki11's Avatar
radiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond repute
Default Re: ls/vtec///NEED HELP
on the front of the head the b17 head is stamped PR3 . gsr has a stamp of P72 on the front .gsr and B17 heads have different intake manifold bolt patterns . and a B17 head is the same thing as a B16 head so ya know
Old Oct 9, 2008 | 07:31 PM
6_speedeg's Avatar
Lurking....
ok thanks man
Old Oct 9, 2008 | 08:11 PM
radiaki11's Avatar
no problem. Good luck
Old Oct 10, 2008 | 11:30 AM
6_speedeg's Avatar
Lurking....
my car is kinda slugish and when i stop at a light it idles at like 1500 and then drops to between 800 and 1000 rpms any idea what my problem is??????
Old Oct 10, 2008 | 12:49 PM
ls/vtecstitch's Avatar
Whatever it takes
ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch
clean your IACV?
Old Oct 10, 2008 | 01:23 PM
6_speedeg's Avatar
Lurking....
ok ill try that, thanks man
Old Oct 10, 2008 | 01:34 PM
radiaki11's Avatar
could also be sluggish do to ur tps not being in the correct voltage range
Old Oct 10, 2008 | 02:56 PM
snarf's Avatar
sky's the limit
snarf snarf snarf snarf snarf snarf snarf snarf snarf snarf snarf
yeah, your TPS sensor may need calibration.
http://www.skunk2.com/skunk2_videos....ch+%2F+Install
first video on that list, the guy calibrates the tps sensor.
Old Oct 13, 2008 | 12:49 PM
willie's Avatar
willie has disabled reputation
CARS ARE SUPPOSED TO IDLE AROUND 600 TO 800 RPM if your car is idling at 1500 you have another problem done worry about the 800 idle thats fine but now if it flucuiates between 800 and 1000 like going up and dow and up and down the look at your mixture screw somebody may have messed with that
