95 teggy bog problem
i just got this teg an it had a different ecu so i just got the stock one but the car has a bad lag thru 3.5k rpms an its running real lean idk if there from the same problem or what but even after i got the stock ecu its still bogging any ideas? oh its a stock ls no wiring problems from what i can tell i was thinking the alt. was going bad lmk what yall think edit..now the plug cylinders are filling with oil 4-3 an 2 are filled with so much oil you cant see the sparkplugs...im at a lost i changed my gasket an grommets idk how else to stop oil from coming in
Re: 95 teggy bog problem
Had the same problem when I bought my crx. Dude told me it was timing, but the lifters werent pumping up to open the valves, so it ran real lean, had to replace all the lifters. Maby something to check into, but thats just my .02
it doesnt have a cel all the time but it will just pop on going down the road an now i pulled my plug wires an found the cylinder where the plugs are full of oil so i replaced the valvecover gasket an gromits an it did the same thing right away im thinkings thats the problem but how is the oil getting in there im at a lost
even tho no one has helped but oil is getting on the top part of the plugs alot i tryed a new vc no good im at a lost how is oil getting into my plugs! help!!
