91 Hatch cable transmission issues
Old 08-26-2012, 01:45 PM
Irubonrights's Avatar
Irubonrights has disabled reputation
Default 91 Hatch cable transmission issues
So I finally got my civic project running..I went to shift car into first but it will not go.. I went through all gears and none worked..when I went into reverse it grinds like crazy.. I cut car off and I can get through all gears with ease.. Ive done some research and they say put it in first then cut car on.When I did this the car went forward as if my clutch as engaged and i pressing the gas... I have adjusted my cable but still same issues.. my question is where do I start? I didnt install clutch to block all that was there when I brought the car. and was told that the transmission worked fine when the motor went out...
Irubonrights is offline
Old 08-29-2012, 09:46 PM
jminter92's Avatar
jminter92 has disabled reputation
Default Re: 91 Hatch cable transmission issues
if adjusting the cable isnt doing anything id pull the tranny and check the clutch and pressure plate and release bearing one of the 3 sounds like the problem to me!! its not disengaging.
jminter92 is offline
Old 08-29-2012, 10:12 PM
The clutch fork I think its called..... should that be set all the way up and the cable be adjusted with very little slack ?
Old 09-02-2012, 03:24 PM
TNGChris's Avatar
The engagement arm should be down when the pedal is in the released position.When you compress the pedal it should pull the arm up to disengage the clutch.If the arm moves freely up and down or is stuck in the up position you need to pull the tranny to see what's wrong in the throwout bearing assembly.
TNGChris is offline
Old 09-15-2012, 03:41 PM
s14kouki's Avatar
s14kouki has disabled reputation
yea definitly sounds like its staying engaged...
s14kouki is offline
customhonda
Engine / Exhaust / Drivetrain
08-25-2013 01:25 PM
Dillweed
64
03-27-2011 10:47 AM
AllMotorAllDay
12-29-2010 05:44 AM
tegd-out
12-06-2002 06:35 AM
Quick Reply: 91 Hatch cable transmission issues
