89 civic si fuel filter, any suggestions on breaking banjo nut?
Old Aug 10, 2007 | 05:55 PM
vitamin ef's Avatar
vitamin ef has disabled reputation
Default 89 civic si fuel filter, any suggestions on breaking banjo nut?
Trying to get my fuel filter off, fucking fuel is muddy in the bottom, i can break the 18mm bolt and the 12??mm nut that relieves the pressure, impact wrench for the win, but the oval shaped banjo nut is not breaking, had two people on it with wrenches and pliers and straps, etc... problem being is the fuel filter is of course loose, and ur basically holding it in midair to break the bolt, any suggestions? ideas? tools that work good for it? I was considering a 20/21 mm socket but, it's not made for a socket, wondering if one would be able to get a grip on it, regular open end of a box wrench grips it but, it won't break...
Anyways.. any shops wanna give me an estimate? I got parts, may need 2 new crush washers on one of the bolts cause I used 2 new ones, anywhoo... hit me up, appreciate it
Old Aug 11, 2007 | 07:49 PM
torturedsol's Avatar
torturedsol has disabled reputation
Default Re: 89 civic si fuel filter, any suggestions on breaking banjo nut?
1 person hold the filter and the other use the impact gun lol. New banjo bolt is like $5 at a Honda stealership if it breaks. Sounds like that filter hasn't been changed since 1989 lol
Old Aug 11, 2007 | 07:52 PM
important's Avatar
important is an unknown quantity at this point
Drill a hole directly through the center of the fuel filter and then put a long,strong screwdriver in its place,while someone holds it use the impact.or just get a new rubber fuel line and bolt.
00civicman
Jul 30, 2008 12:46 PM
usmcbugle85
Dec 5, 2006 06:20 PM
hondazccivic
Sep 23, 2006 05:46 PM
