89 b18a1 hatch lots of oil in combustion chamber
Old Jun 25, 2007 | 10:08 AM
krazdracer's Avatar
krazdracer has disabled reputation
Default Re: 89 b18a1 hatch lots of oil in combustion chamber
Originally Posted by sive ick
btw you didnt remove the oil limiter(?) on the block did you,causing the bottom end to push more oil up top then leaking onto the pistons through in correctly installed valve seals and quides,not to mention does it have a good and new head gasket
the seals were installed proffesionally and it does have a new head gasket. I'll look for the oil limiter could you elaberate please?
Old Jun 25, 2007 | 10:09 AM
sive ick's Avatar
sive ick is an unknown quantity at this point
well its a oil flow restrictor on the block,it limits the amount of oil that is pushed to the head,so you cant check that out without removing the head,you may just have worn out cylinder walls
Old Jun 25, 2007 | 10:14 AM
sive ick's Avatar
Old Jun 25, 2007 | 02:28 PM
krazdracer's Avatar
but it was bored out and honed right before the intial 250miles says the machinist who bored it.
Old Jun 25, 2007 | 05:14 PM
DeFunk's Avatar
DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk
Incase you're still wondering where it is if nothing more than to maybe learn something, assuming you dont know already.
Old Jun 26, 2007 | 07:19 AM
krazdracer's Avatar
Originally Posted by DeFunk
[img]
thanks i'll check that when we take the head off
Old Jun 26, 2007 | 08:32 AM
Jarrod's Avatar
braap braap
Tell Calvin to find me a way over there.
I need to do a valve adjustment on it anyways and I'll take a look at it while I'm there.
I think I know whats going on. Who rebuilt it?
Who bored it? What pistons are in it? Who file fitted the rings? Who honed it?
Who went thru the head to make sure everything is ok?
Old Jun 26, 2007 | 09:18 AM
sohc_mshue's Avatar
Originally Posted by krazdracer
dude no..... it is smoking while runnng all the time and the plug tubes are clean we replaced all of the seals in the valve cover
in that case then you probably have some serious issues.
How was the motor ran during break in? Just bone stock ls i assume? Were you using a stock ls computer or a basemap of some kind? If it was running too rich from a possible bad basemap then you could have messed your cylinders up bad.
Also you say theres no blowby coming through the pcv at all? Do a leakdown test. If it comes back good then look towards it being your valve seals.
Old Jun 26, 2007 | 11:26 AM
1rude2l's Avatar
another possible scenario, did the head have bent valves, if so was the guides replaced if they were cracked, had a talon do the exact same thing, although i never got oil in the cylinder. Oil was leaking on the exhaust valve side. burning it from the heat. Car smoked like crazy. start it and you couldn't see behind the car. Even new valve seals didn't stop it cause the valve could wobble some and the seal would leak. just a thought. could leak oil on either side though intake or exhaust mine was just on the exhaust side so i never got oil into the combustion chamber
Old Jun 26, 2007 | 12:06 PM
krazdracer's Avatar
me and calvin rebuilt it the second time. the machinst file fitted the rings
