1998 Eclipse GSX having Turbo Problems Help Please!!!
Old Feb 25, 2009 | 04:41 AM
  #21
bryan64613's Avatar
Team Dickbutt #13!!!
bryan64613 bryan64613 bryan64613 bryan64613 bryan64613 bryan64613 bryan64613 bryan64613 bryan64613 bryan64613 bryan64613
Default Re: 1998 Eclipse GSX having Turbo Problems Help Please!!!
Originally Posted by Newbsauce
Doesn't help much if you don't provide more information regarding the symptoms. 92k miles doesn't mean anything, my stocker had 130k on it with very little shaft play.
Well I already told my friend to take it to Auto Parts, but he hasn't get a chance to take it. I should have an answer by Friday or Saturday the latest.
Thanks once again for all the help.
Old Feb 25, 2009 | 04:46 AM
  #22
bryan64613's Avatar
Originally Posted by HighPSI TSi Guy
Well the description is not great but my guess is either boost leak, stuff hooked up wrong, or blown turbo. I've seen some wierd shit caused by blown turbos before. I certainly hope your friend isn't driving it with lines disconnected.
My friend was also telling me that the stock Boost Gauge doesn't even move when you are driving. I don't know if that means that the Turbo is dead. Well he actually drove the car to work like two days ago, but I'm not sure if he is driving it every day. What happens if you drive the car with the lines disconnected??
Old Feb 25, 2009 | 06:56 AM
  #23
buugiewuugie's Avatar
Zombies found Waldo
The only thing the stock boost gauge is good for is... well nothing. You shouldnt have to look at the boost gauge to know if its getting boost. You should feel it no matter if it's 5 psi. I am not nearly as experienced as the other DSM guys mentioned in this thread. But it sounds like a bad turbo, If a tube was not connected properly the car would feel like its hitting a wall at WOT, and run shitty. and also is that BOV recirculated? Unless you are running the GM MAF I would reccomend throwing the stocker back on. Or a 1g BOV, they can be had for cheap and work great.
Old Feb 25, 2009 | 07:20 AM
  #24
GreatShamanGT's Avatar
GreatShamanGT has disabled reputation
You need to get a boost gauge. Seriously, even get a cheap autometer gauge. This can tell you how much vacuum you're pulling, etc. You definitely need an aftermarket boost gauge. The turbo timer doesn't help unless you've got a lot of aftermarket parts imo.
Old Feb 25, 2009 | 07:41 AM
  #25
Zombies found Waldo
It doesnt help because the turbo is oil and water cooled. But it cant hurt either. I say keep it, he may decide to go with an aftermarket turbo later on.
Old Feb 25, 2009 | 07:57 AM
  #26
SPAWN's Avatar
I <3 My DSM
SPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud of
ya beat me to it...i was thinking the EXACT same thing...if lines arent connected, there WILL be a a blown/seized turbo very very soon....that is, if its not blown already...
Old Feb 25, 2009 | 08:25 AM
  #27
HighPSI TSi Guy's Avatar
❒Good ❒ Better ✔Best
Driving a malfunctioning vehicle just creates more problems. Sadly, this seems to be the number 1 passtime of VaDriven members.
Old Feb 25, 2009 | 08:53 AM
  #28
Newbsauce's Avatar
1.6L Elitist
Newbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these partsNewbsauce is infamous around these parts
DSM guys can keep me honest here, because its been a few years, but isn't the OEM boost gauge simply controlled by the ECU based on estimates rather then air pressure? A malfunctioning gauge in your cluster (I won't even refer to it as a boost gauge) can be caused by something other then a "broken turbo."
Old Feb 25, 2009 | 12:23 PM
  #29
That is correct. It just tells you a number based off the ECU calculation of "airflow". It's pretty accurate on a stock car. But as soon as you change the air filter it's useless.
Old Feb 26, 2009 | 12:00 PM
  #30
weldmatic's Avatar
weldmatic has disabled reputation
Originally Posted by streetlamp
Why do you think the turbo sometimes and sometimes doesn't work (down on power, boost gauge not showing anything)? If its basically stock then you wont really hear the BOV. Does the car have a boost gauge besides the stock one?
on some models the wastegate gate actuator fails from rusting away....
sounds like the wastegates failing. or an issue related to it..
cel from too rich condition
