Aircooled VW 2007cc Engine Longblock
Means of contact: Email/Text
Price: $2000.00
Description:
I have a Volkswagen 2007cc motor that has about 30k miles on it. Makes roughly 130 at the crank (with dual 40 Dellorto DRLA's) . Long block only with oil cooler, Flywheel, Pressure Plate, Clutch, merged header and custom single glasspack exhaust. Some specs.
Full Flowed AS21 case
Deep Sump
CB 044 heads
CB Pushrod tubes
Chromoly pushrods
Cima Pistons
Straight cut cam gear
30mm oil pump
Vented Valve Covers
This Engine is currently in my DAILY car which speaks for itself. Very dependable and strong. The engine will stay in my car until its payed for then ill pull the engine for pick up. Email- wicked1lbc@gmail.com Text- 5623971794. If you like you we can even meet somewhere so you can look at it. hear it run. test drive... You can also watch me pull the motor if you want hahaha... Thanks for looking!
Pictures:
Price: $2000.00
Description:
Deep Sump
CB 044 heads
CB Pushrod tubes
Chromoly pushrods
Cima Pistons
30mm oil pump
Vented Valve Covers
Pictures:
