Gas
Old Aug 6, 2006 | 12:50 PM
The_rabbit1's Avatar
Fidel runs VBPD
The_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud ofThe_rabbit1 has much to be proud of
Default Re: Gas
street bike motors are high compression, therefore 87 should definitely be knocking. My bike is old but i still use premium.
Old Aug 6, 2006 | 01:18 PM
skr00zloose's Avatar
hatrs make me famous
Default Re: Gas
ex500's aren't high compression by any means. it'd probably run fine on 87, but the heat we've had lately may being playing into it. i run 87 in my chop, which probably has about the same c/r as an ex, and it runs fine. but mine's also been jetted for the temp outside.
Old Aug 6, 2006 | 01:19 PM
Default Re: Gas
Originally Posted by ZeRo_c0oL@work
Trey's is much quieter than mine, and he claims that's what he did.
...and yes, my chain is clean and always well lubricated.
clean and well lubricated?? what?? i'm talking about the cam chain, not the drive chain...lol.
Old Aug 6, 2006 | 01:34 PM
VanillaThrilla's Avatar
wub wub wub wub
Default Re: Gas
I know you're talking about the cam chain.. lol. I was too, and then I went off to say it's not my drive chain that I'm referring to when I say it's noisy. That was confusing I guess, the way I said it. lol. Sorry
Old Aug 6, 2006 | 02:00 PM
Armenian's Avatar
CLUTCH IT UP
Armenian has disabled reputation
Default Re: Gas
Yep.
So is my 636.
There's a trick to the tensioner to where you turn it off and put it in 6th gear and roll it whatever distance and it's supposed to adjust the cam tensioner supposedly.. Haven't done enough research about it to make it work for me, but it's noisy as it is.
Turn bike on, put it in 6th gear, turn bike off, roll bike reverse while in gear. More of a temporary fix permanent fix is a manual APE CCT.
Old Aug 6, 2006 | 02:05 PM
djgrom's Avatar
LaShawn
Default Re: Gas
Ummmm, wow. If I had a super power I would be able to touch people and gain all of their knowledge
Old Aug 6, 2006 | 04:25 PM
Default Re: Gas
ah...ok... that makes sense now, no one said anything about rolling the bike BACKWARDS. that would slacken the rear of the cam chain, letting the tensioner come out a click or two. i gotcha.
Old Aug 6, 2006 | 06:32 PM
CBR600F4's Avatar
Va Beach Coast Rider
CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4 CBR600F4
Default Re: Gas
yeah, can't hurt anything.
Not true............
First track day; ran out of gas. Borrowed some 93 from Mark. First straightaway I almost got bucked off the bike.
Run what it tells you to run.
EDIT:
If the bike is stock that is.
Old Aug 6, 2006 | 07:41 PM
wub wub wub wub
Default Re: Gas
Thank you.
I was about to call his ass up and see if he was just messing with me when he advised of the "fix"
Old Aug 7, 2006 | 07:28 AM
Default Re: Gas
EDIT:
lemme get this straight, you ran 93 octane in a your stock motored cbr and it almost bucked you off? i don't think the gas was the problem there buddy.
