trouble for not being carb exempt?
Old Nov 8, 2004 | 05:23 PM
Terry@Fortune's Avatar
Default Re: trouble for not being carb exempt?
Originally Posted by DOHC B18
www.nasioc.com
dont look for too much answers on here for subie Q's. if you are going to eliminate all the restriction on the sti exhaust i would look into www.turboxs.com for full exhaust systems for better flow. as far as up-pipes go, alot of people i see go for the helix flex uppipe. i went for a full HKS setup(up,down/catback exhaust) no cats on my car and has an awesome rumble to it. i havent heard anything bad on Borla uppipes..but read a little of this before you buy. i wish i did. just my .02
READ ME!!!
yeah upipe is a waste of $$
Old Nov 8, 2004 | 05:32 PM
Up_on1's Avatar
Murdered Out
i heard header is for subie....TBE isnt a waste
Old Nov 8, 2004 | 05:39 PM
yeah header is kinda worthless too.....but the upipe has nothing to do with TBE
Old Nov 8, 2004 | 05:43 PM
Up_on1's Avatar
Murdered Out
what about blk headlights terry?
didnt say uppipe was part of the TBE focker....stating the obvious...just like jAy zEy zEy oWnZ
Old Nov 8, 2004 | 05:55 PM
lol
Old Nov 8, 2004 | 06:00 PM
HatefulMechanic's Avatar
The Pro to call.
nabisco sucks ass.
get a TBE with a high flow cat, and you will be legal and have power. the TXS has fitment issues i have seen, the Godspeed one fits the stock cat, and the Perrin has been discontinued.
i modify the Invidia DP and add a 3" high flow cat. takes a little time to fit and make right, but it works well.
no need to do an uppipe on the STi, of course, and headers dont help the stock turbo. however....they do help if ya run a large turbine (the 34 is questionable, you lose low end spool, but you dont have as much top end taper, but on a 22 or an 18g or larger, it helps.)
you do not have to be CARB approved in VA, as long as the vehicle has emissions equipment of OE style, then you are fine. you dont have to worry about a loaded IM240 test either, you will just get an idle and off idle sniffer test. (no AWD dyno required for that.)]
Old Nov 8, 2004 | 06:16 PM
this man speaks the truth
Originally Posted by fc735
nabisco sucks ass.
Old Nov 8, 2004 | 07:08 PM
AdrenalineAuto's Avatar
1-877-TURBOKT
AdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud ofAdrenalineAuto has much to be proud of
Originally Posted by chibich
I am looking for headers and an up-pipe, but the only ones I have found that are carb exempt are the borla. does anyone know what trouble i would get in if i was not carb exempt, or if my catalytic converters will take care of it? (any info helpful!!!!)
I have an STI and i have no cats, i can pass inspection through friends anyway. An yes the cat is the biggest downfall. Also just a tip for the future from personal experience(lol) get aftermarket axles www.driveshaftshop.com
Borla headers are the cheapest, and they give a 30 hp increase i think.
Old Nov 8, 2004 | 07:16 PM
ClassicJDMCars's Avatar
30 hp huh? and i bet a air intake will let you chirp 4th gear right?
Old Nov 8, 2004 | 07:22 PM
yeah seems excessive for some headers maybe there specially designed with nos additives?
