Cleaning Carbon Fiber
Old Dec 10, 2007 | 12:21 PM
sp3nce's Avatar
sp3nce is an unknown quantity at this point
Default Re: Cleaning Carbon Fiber
Originally Posted by Fabrik8
No.
There is a whole 3M product line for that. I can't remember the name either though. The resin/gelcoat used for most carbon hoods is the same polyester resin/gelcoat used for most boats, which is why it works so well. Better ($$$) hoods are made with epoxy, and can't be polished with the same products.
Really though, get the hood clearcoated and you can care for it the same way as the rest of your paintwork.
thanks man. yeah, its clearcoated so I'm just using regular wax/polish.
another question for those pros at cleaning..
is there anyway to protect rims from breakdust getting all stuck up in it? those are bitches to clean >_>
Old Dec 10, 2007 | 12:31 PM
You can wax your wheels too.. There are some special waxes that are higher temp than standard (paint) waxes, but I don't think they're really necessary. Really any type of wax will help with brake dust cleaning, just the same as it's easier to clean a waxed car than a non-waxed one.
Old Dec 10, 2007 | 12:34 PM
sp3nce's Avatar
im good with cleaning the break dust off. I'm looking for preventative means... .as far as keeping the dust off from regular driving.
Old Dec 10, 2007 | 12:53 PM
nis240drft's Avatar
nis240drft has disabled reputation
I know this is off kinda off topic but does anyone knw the "right way" to cut carbon fiber. I have cut a few of my scrap peices covering both edges with masking tape It worked ok Had like 2 small chips flake off.
Old Dec 10, 2007 | 01:25 PM
WALL-E's Avatar
WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E WALL-E
I just use quik wax on it as im drying the car. Same as paint.
Old Dec 10, 2007 | 01:27 PM
Flite's Avatar
HHIC
Paint your hood
Carbon/ceramic brakes. They're cheap.
Old Dec 10, 2007 | 06:37 PM
Are you trying to cut, drill, what are you trying to do?
Regular drill bits are horrible for composites and plastics; there are special drill bits (with a higher included lip angle, etc) if the holes are small, and if the hole is large your best bet is to use a very fine toothed hole saw. There are also carbide grit cutting burrs that work great in a Dremel tool or angle grinder to make small holes larger. If you're making a hole for hood pins or something like that, starting with a small hole and carefully enlarging it with a Dremel is safe and easy. There are also carbide grit saw blades for jigsaws, and a really fine tooth metal cutting blade works well usually. You're dealing with a composite that has layers stacked on top of each other, so if you use any type of cutting tool that can grab and pull a layer, you're going to have big problems. It really comes down to what direction you're cutting, and what direction the material wants to go when it's removed.
Old Dec 11, 2007 | 05:59 PM
ted's Avatar
ted
Bicyclist for now
ted has disabled reputation
Originally Posted by Kris.is.awesome
Claybar it, and wax it.
Claybar ftw. I remember using that sometimes when cars really needed it at the dealership.
Finishing polish will also do a great job on anything.
By the way, what up Spen?
Scotty_Nooo
Want to Buy / Trade ARCHIVE
Feb 9, 2008 01:19 PM
watisjdm
Oct 17, 2007 07:26 PM
