Long But Please Read
Old Nov 20, 2005 | 03:51 PM
  #291
LLama's Avatar
Unconfirmed User
LLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond reputeLLama has a reputation beyond repute
Default Re: Long But Please Read
so.... what about those mid 7's? what'd he run?
Old Nov 20, 2005 | 04:41 PM
  #292
BOOST FED 95Z's Avatar
07 TL
BOOST FED 95Z has disabled reputation
Originally Posted by silvcobra
You talked earlier that night as if your car was running great. You even recommended I take the kick. Bring it on...
Oh god...you found us.
Scott
Old Nov 21, 2005 | 07:26 AM
  #293
James93tsi's Avatar
Coastal Carolina U
James93tsi has disabled reputation
He didn't get to run at the track. I was going to go with him up there but the plugs had to be replaced and the car still isn't running right. After he raced the cobra (the second time) the car was struggling to idle and at low rpm's the whole car was shaking from the engine vibrating so bad. Rotorsownyou7 had this happen to him when his engine blew in his TT so who knows what could be wrong with it now. Good luck Blake on getting this one fixed.
Old Nov 21, 2005 | 08:11 AM
  #294
LLama's Avatar
Unconfirmed User
struggling to idle and at low rpms the whole car was shking from the engine vibrating so bad...
compression test time.
Old Nov 21, 2005 | 08:28 AM
  #295
1badR1's Avatar
1badR1 is an unknown quantity at this point
its blown up
Old Nov 21, 2005 | 08:40 AM
  #296
2.3L TURBO 4D's Avatar
2.3L TURBO 4D has disabled reputation
sounds like what my car did when the belt slipped off the water pump under 22 psi...it cracked the head gasket in 6 places... and when we took the head off i had a puddle of oil sitting on top of the #3 piston
Old Nov 21, 2005 | 10:11 AM
  #297
James93tsi's Avatar
Coastal Carolina U
After the plugs were changed it got a little better but now it is running a lot richer. It is running all 9's on leading and trailing rotors and rotorsports said to change it up to 9 on leading and 7 on trailing (or the other way around i forgot) and see how it does then. I really hope it is not blown after the first day he drives it around on a single turbo. A compression check should be done soon (very soon) to see what it pulls.
Old Nov 21, 2005 | 11:04 AM
  #298
HSP_DSM's Avatar
#1424
HSP_DSM has disabled reputation
agree...good luck though blake!
Old Nov 22, 2005 | 06:08 AM
  #299
Single turb007's Avatar
Ahhhh
Single turb007 has disabled reputation
Changing all the plugs AGAIN today, up dates on hows it running later.... and Silvcobra, good run. A win is a win and a lose is a lose. But, i hope to get the car running right by this weekend, maybe we can try again. You do have to remember, that was the first time i have raced my car in 8 weeks. And that was the 2nd day after i had got it back, but im not going to be a sore loser, good run, and you have a really quick car.
Old Nov 22, 2005 | 10:37 AM
  #300
pivt's Avatar
pivt has disabled reputation
let me know when u get it running right........Im def. interested in a run.
