wire harness problem
Old 12-13-2009, 08:50 PM
fiveomike's Avatar
fiveomike has disabled reputation
Default wire harness problem
can u do away with the air intake temp. sensor? I have a 96 ls b18b non vtec swap into my 95 civic my stock engine harness does not have the plug for the air intake sensor what can i do to solve this?
fiveomike is offline
Old 12-13-2009, 09:12 PM
johncarlito's Avatar
johncarlito has disabled reputation
Default Re: wire harness problem
find it cuz u need it! find out the pins at the ecu,(this is ,if you used your stock civic harness) look at the color to see if it in the engine harness ! if not u should at less find the wire in shock tower plugs on the passenger side .. and run your wire from there to the sensors>
johncarlito is offline
Old 12-14-2009, 04:15 AM
Your ECU runs off of a speed-density management strategy, which means it calculates air and fuel based on engine speed and air density. To calculate air density, you either need a MAF sensor or a MAP and intake air temp sensor (and Honda ECUs don't use a MAF obviously).
If you don't have an intake air temp sensor, all you'd be measuring is air pressure, and that doesn't tell you anything about the air density because the density is temperature dependent at any given pressure.
I could have just said no, but I wanted you to know why the answer is no.
That plug has to be there somewhere, and if someone has removed it then you need to add it back.
Old 12-14-2009, 06:05 PM
damn vadriven at it's best!!lol!
Old 12-14-2009, 06:08 PM
LIKE A BOSS
jdm monkey's Avatar
jdm monkey jdm monkey jdm monkey jdm monkey jdm monkey jdm monkey jdm monkey jdm monkey jdm monkey jdm monkey jdm monkey
ture, unless he's running alpha-N
jdm monkey is offline
Old 12-14-2009, 06:16 PM
Ramey Built
JB@RameyBuilt's Avatar
JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt JB@RameyBuilt
Fabrik8 is the man. If I could, I would +rep you.
JB@RameyBuilt is offline
Old 12-14-2009, 06:27 PM
yeah your right, but then again ,why would he?!
Old 12-14-2009, 06:36 PM
That's so remote it isn't even worth mentioning.
Old 12-14-2009, 06:46 PM
LIKE A BOSS
jdm monkey's Avatar
if he's running ITB's
yeah, +rep tho. i would not have patience to help people but u do.
Old 12-14-2009, 07:16 PM
once again i find myself at a pointless discussion !
Quick Reply: wire harness problem
