WIll it work? help needs!
Old Nov 4, 2007 | 09:47 AM
hatch213's Avatar
hatch213 has disabled reputation
Question WIll it work? help needs!
I took suspension off of a 94 integra ls w/ struts, coilovers, brakes, everything and i have a 94 civic hatch dx (eg body) WILL it fit the hatch......i heard some have worked and others have not. something about the abs will create a problem in the hatch b/c it doesn't have abs? and could i use the stock proportional valve or will i need an aftermarket one? help a bud out. if not thanks for your tymeeeeeee
Old Nov 4, 2007 | 07:54 PM
B-Well's Avatar
I Love to Hate
Default Re: WIll it work? help needs!
Everything will bolt up but it's gonna ride higher cause that teg was heavier. Also, you can use the teg prop valve and master cyl if you'd like. As for abs, I'll look it up unless someone else chimes in before I do.
Old Nov 5, 2007 | 10:09 AM
CHAHONDA's Avatar
corona connessuer
your car does not have abs therefore the abs portion of the teg brakes is rendered useless. youll be fine...you just dont hook it up.
shaggy240sx
Dec 27, 2008 05:42 AM
6CYLINDRSYMPHNY
May 20, 2008 02:04 PM
Ls_pwr
May 12, 2004 07:05 PM
FlipLegend
Jun 13, 2003 12:35 PM
