will a obd1 ls alternator work on a obd0 jdm b16 in a obd1 eg hatch
Old 12-21-2009, 06:44 PM
jdmb16hatch's Avatar
jdmb16hatch is an unknown quantity at this point
Default will a obd1 ls alternator work on a obd0 jdm b16 in a obd1 eg hatch
Ok my alternator is going out, the person i got the swap from had a sohc alternator rigged on it with spacers.
I have a obd1 ls alternator that plugs in and will bolt up but dont have the adjustment to make the ls belt or sohc belt fit
have been told to use washers on the bracket or to get a smaller belt
any suggestions? will the ls alternator work?
thanks
jdmb16hatch is offline
baller/dickbutt#69
nftuatn's Avatar
Default Re: will a obd1 ls altinator work on a obd0 jdm b16 in a obd1 eg hatch
Originally Posted by jdmb16hatch
Ok my altinator is going out, the person i got the swap from had a sohc altinator rigged on it with spacers.
I have a obd1 ls altinator that plugs in and will bolt up but dont have the adjustment to make the ls belt or sohc belt fit
any suggestions? will the ls altinator work?
thanks
i doubt it...now an alternator on the other hand may work
nftuatn is offline
Old 12-21-2009, 07:01 PM
lol thanx for the spell check
Old 12-21-2009, 07:51 PM
wright's Avatar
The Alt will most likely work, but I think that the plug (wire plug) might be different.
wright is offline
Old 12-21-2009, 08:40 PM
Default Re: will a obd1 ls alternator work on a obd0 jdm b16 in a obd1 eg hatch
I think that's a drop-in replacement if you have an OBD1 car, if you get the proper belt for it. Get a del Sol or 99-00 Civic Si belt, either should be a perfect fit.
Can anyone verify this? I've been out of the Honda game for a long time.
Old 12-21-2009, 09:01 PM
johncarlito's Avatar
johncarlito has disabled reputation
yeah it should..
johncarlito is offline
Old 12-22-2009, 07:31 AM
wright's Avatar
I did not read this right. The LS Alt will work you might have to take back the belt a few time until you find one that will work.
wright is offline
Old 12-22-2009, 07:34 AM
Mindless's Avatar
Mindless is an unknown quantity at this point
Or just swap pulleys.
Mindless is offline
Old 12-22-2009, 02:27 PM
thanks i think im am going to track down a smaller belt
H. Love
10-01-2007 06:19 AM
Quick Reply: will a obd1 ls alternator work on a obd0 jdm b16 in a obd1 eg hatch
