what clutch will work in cable zc tranny
hey guys i put a dohc zc cable tranny in my 91 ef hatch few months back. was given clutch to put in and forgot the number of splines on it. now i know its differnt than a dx tranny. i need a new clutch and i dont know wat car to order it for. lmk if yall know. thnx.
there are two different zc trannys- For my tranny the CRX SI clutch was the one to use for the 212mm version with 20 splines- just count your splines to see if yu have 20 or 21( 20 spline is better). the older ZC trannys use the smaller clutch and are 21 spline- you can convert it though
ok....so when i pull it out i will just count it....i think it was 21 but cant remember. so if its 21 what would i order it for? i thought there was only one for zc trannys,just the ones that came with the dohc ones. the jdm versions.
go to thezcr.com. i know if you have the 21 spline count you need the 200mm clutch. I know act sells a version of the clutch you need. I think it would come from the 88 crx- just make sure its 21 spline count and it should be the 200mm
appreciate all the help guys i found that if i order for a 89 integra its the right one cause thats the usdm dohc zc which is the same tranny.
