weird fuel pump problem...Walboro255
Crx w/Walboro255 (in tank fuel pump)
Today I drove my car about 2 miles to Advance. Everything seemed the normal. Turn the key, hear the loud ass fuel pump prime "wheeeennnnnnn" and car starts. I go in buy a couple of fuses come back out. turn the key and start the car. The car starts, bogs down, shuts off. thats when I realized that the fuel pump didn't prime as usuall. so I turn the key to ACC, just before starter, which should kick off the fuel pump. nothing. Try to start it anyways. no way car will have no part of it, stutters and shuts down.
Now I am freaking out, I'm fucking stuck at Advance. I disconnected the coupler to fuel pump and reconnected it and jiggled the wires around (why does this always work?). I also got out and rock the car back and forth. Turned key to hear the familar whine, car starts. Wiring? trash in the Tank?
any ideas?
any ideas?
DESTROYS DONUTS !!
Re: weird fuel pump problem...Walboro255
you got me dude, my walbro does the same thing sometimes, and i know all my connections are good cause i am the soldering master, but sometimes it wont prime when i turn to ignition 2, dont know, wish i could explain it.....
thnks
Originally Posted by MitsukillinSi
at least it was advanced. All the shit you need was right there
Bitches get Stitches
i've never had a problem with mine and i've had it in about 2 years at least. maybe some of them are just quirky. i'm using one designed for a gsx but i doubt that would have any difference.
Mine did the same thing in my integra when i first put it in. The car would run for a couple of seconds and then it would shut off. It runs fine though now only gave me a problem the first couple of days.
Nonvtec owns you
More than likely the contacts are corroded and need to be cleaned! If thats not it, check the wiring. Wires can go bad; do a resistance check.
TheMx3
02-03-2004 01:18 PM
