VW max boost?
Old Mar 14, 2006 | 05:06 PM
4doorsleeper's Avatar
4doorsleeper is an unknown quantity at this point
Default VW max boost?
i have a 96 jetta gl with a rebuilt motor and minor port work, it also has a t3 60trim turbo setup. i currently have it set at 5 psi, i was just wonderin what would be a safe higher setting?
Old Mar 14, 2006 | 05:13 PM
Corey's Avatar
Yup, jolly poopbuggy
Default Re: VW max boost?
This is a 2.0 liter I'm assuming. I've seen over 20psi with proper fuel and ignition timing.
Old Mar 14, 2006 | 05:45 PM
hondazccivic's Avatar
hondazccivic is an unknown quantity at this point
20psi on stock internals? I think that would be pushing it, thats like adding close to 200hp. Correct me if I'm wrong but i don't think it could run that much on the stock bottom end, valve train, etc..
Old Mar 14, 2006 | 06:13 PM
Dick's Avatar
Dick has disabled reputation
maybe 15psi with chip tuning and a fmu. with engine management yes it can be done on stock internals. vw rods are strong
Old Mar 15, 2006 | 07:15 AM
G60ING's Avatar
Corrado Butcher
G60ING is an unknown quantity at this point
I don't think I would recomend a stock aba motor to run more then 14-15psi. Esspecially without standalone and dyno time
Old Mar 15, 2006 | 07:30 AM
VanillaThrilla's Avatar
wub wub wub wub
That's what I was going to say..
I'd play it safe and take it no further than 8-11psi... and definitely keep an eye on everything so that you can catch any symptoms of problems before it becomes a serious issue.
Jarrod
18
Feb 13, 2009 07:58 PM
Wii
Dec 7, 2003 06:53 AM
