VW check engine code question?
Old Jun 2, 2007 | 01:52 PM
PJ2's Avatar
PJ2
PJ2
Default VW check engine code question?
For those of you that know about VWs, how do you reset the check engine codes on a 2000 4Motion Passat? I have an emissions code and will like to reset it before replacing the O2 sensors to see how long it takes for it to come back. Thanks.
Old Jun 2, 2007 | 03:11 PM
HatefulMechanic's Avatar
The Pro to call.
Default Re: VW check engine code question?
you will need either a generic OBDII scantool, or VAG-COM.
why should it be coming back? the point is to fix cars is it not?
Old Jun 2, 2007 | 04:42 PM
PJ2's Avatar
PJ2
PJ2
You're correct, I want to fix it but the code appeared the day a local VW dealership worked on something else and the sensors have already been replaced once since then. I want to make sure they didn't mess up the wiring since they can't figure out what the problem is. So there's no holding of the key or switch trick to reset it then? That sucks...
Old Jun 3, 2007 | 09:16 AM
scr8dubbn's Avatar
what?
scr8dubbn is a splendid one to beholdscr8dubbn is a splendid one to beholdscr8dubbn is a splendid one to beholdscr8dubbn is a splendid one to beholdscr8dubbn is a splendid one to beholdscr8dubbn is a splendid one to beholdscr8dubbn is a splendid one to behold
its a dub man..the only tricks she pulls involve money..and lots of it
bigassturbo
Sep 3, 2008 05:37 PM
Swampdonky
Sep 19, 2006 08:53 PM
crazychickenhed
May 21, 2006 04:46 PM
turboeg6
Jun 16, 2004 12:10 PM
1ns0mniac
Feb 15, 2004 03:52 PM
