Check engine code 13? turbo help
we PARTYIN!
can anyone help tell me how to fix this. i looked it up and it says it is barometric pressure. the check engine light comes on everytime i boost the car hard in third now. ever since i took off the SAFC2 and put on the 3 bar map sensor it bogs bad when i put the gas in alot, it like hesitates to spool. i checked most of the pipes. i didnt find anything loose. something isnt letting it spool right. help. thanks
Re: Check engine code 13? turbo help
Its got to be with your wiring when you took out the SFAC2. Those wires really need to be soldered back together and everytyhing. Double check it. If it ran fine before and now doesnt sence you took it out, Signs lead to that .
