Valve Guide Installation
Your Local DSM Tech
Ok I bought bronze guides and some new SS valves for my car, problem is im in WV and havent a clue about any machine shops around here. I dont really like trusting someone i dont know (machine shop wise) to mess with my stuff. Ive done all the work to my motor myself.
The reason im putting new guides in the head is because i have a valve that is slightly bent and i dont wanna risk just throwing new valves in the head w/o new guides. The head is a DOHC Aluminum Mitsubishi head.
I've read online that you can just throw the bare head in a grill at a certain temp, then push the guides out. Now that is fine and dandy but what is a safe temp to where i wont warp the head? Also what do i do to reinstall the guides?
I know im gonna have to reseat the valves since the guides wont be sitting in exactly the same place as before. So i dont need to know that. Any helpful tips or any advice would be much apprecieted!
The Pro to call.
Re: Valve Guide Installation
i usually press them out.....i have a set of drivers. as for heating the head up and pushing them out, it can be done, but i dont like to....i would say 300ish would be the limit i am not sure on that.
i have a 4G63 head sitting here in front of me actually
and as for lapping valves...i am not much on that. i always use a kwik way valve grinder to get everything set right. lapping will only work on a small amount of material. where at in WVA are you?
hybrid no more :(
you really got the basics of it.. heat the head to certain temerature. make sure you use some kind of heating that heats the entire head to 300 degrees F. do not use a lighter, burner.. you can warp the head. also for the guides, freeze them for an hour before installation. it makes it easier. after that is done, the valves need to be reseated. i've only know about hondas.. also this is for iron guides not bronze. bronze guides may not need to be frozen. i'm guessing mistubishi will be similar. you also may need a tool to remove/install guides, a valve guide driver. HTH
Your Local DSM Tech
I contacted a guy up here about it at a local machine shop and he wants $6-$10 to install each guide, and $150 to recut the valves and regrind the seats.
To bad i dont have that much money to spend on it right now
Your Local DSM Tech
that is a good price though. 300 to do a full valve job is good, very. does he check speing seat pressure too? i am sure he does...
The Pro to call.
yeah. but remember that you need to check the installed height of the springs when you assemble it, since that will affect the spring seat pressure...
