turbo owners
Old Apr 14, 2004 | 12:48 PM
GodsOther's Avatar
Back for more
GodsOther is an unknown quantity at this point
Default Re: turbo owners
I am no expert on this but common sense would tell me that making a fan push air INTO oncoming air (i.e. your travelling forward) would be less than efficient?
Old Apr 14, 2004 | 03:40 PM
2000civicsi's Avatar
D-tuned
2000civicsi has disabled reputation
the only reason you would change your fan from a puller to a pusher is if you install a turbo with an intake and you dont have enough room for the fan. then your going to have to install the fan on the opposite of the radiator and you MUST switch the leads. If dont reverse flow of the fan it will not blow cool air on the radiator. It depends on which side of the radiator you have the fan if it a pusher or puller. That is the ONLY reason you would switch the leads.
Old Apr 14, 2004 | 03:45 PM
GodsOther's Avatar
Back for more
Ok so the air would still be flowing through the radiator towards the firewall it would just push it through vice pull, I was thinking the fan would be on the same side and be pushing air out, thats why I was like uhhh this doesn't sound right.
Old May 2, 2004 | 06:50 AM
ramdog's Avatar
ramdog is a splendid one to beholdramdog is a splendid one to beholdramdog is a splendid one to beholdramdog is a splendid one to beholdramdog is a splendid one to beholdramdog is a splendid one to beholdramdog is a splendid one to behold
thanks for all the replys guy, you all arent so bad after all have aftermarket fan only having problems with install
Old May 2, 2004 | 07:26 AM
bgddyal's Avatar
bgddyal is an unknown quantity at this point
i just cut some fan out
worky worky
Old May 4, 2004 | 11:58 AM
brokedown's Avatar
brokedown is an unknown quantity at this point
make sure you get a pull fan and not a pusher fan
1990CRXSi
Sep 2, 2010 05:39 AM
03volkevo8
Sep 11, 2008 08:25 PM
elementalwindx
Jun 27, 2004 12:31 PM
elementalwindx
Apr 26, 2004 07:04 AM
RatedV
Sep 27, 2003 09:08 PM
