turbo civic need a little help
ok i just picked up a 95 civic coupe. its has a D16y8 motor with a t3t4 turbo set up. it has an OEM rebuild on the whole motor. now onto my questions,
It was originally a dx so it has a p05 ecu. i was told to get a p28 vtec ecu before i get it tuned. is this true or no?
i just need a little information about it any help is great. thanks guys
Also, upgrade headstuds to arp and get a headgasket. Otherwise, if you go into boost a lot the headstuds will stretch. Stock d-series ones SUCK!
The p05 isn't worth a shit to tune with. Plus, I think that one is a economy ecu. I can't remember, so it'd have a 5 wire O2 and would make it un-tuneable for your needs.
Correct. Also upgrading the headstuds and headgasket would increase your boost capabilities.
And if u do have the economy ecu that takes a 5 wire wideband O2, u will need to hardwire a 4 wire narow band into your harness due to the fact that the p28 will not work properly with the wideband signal. Believe me, i learned this the hard way.
