tranny problems...need suggestions!!!!!
Old Jan 17, 2004 | 12:52 AM
BLACK JEFF's Avatar
McLovin
BLACK JEFF is infamous around these partsBLACK JEFF is infamous around these partsBLACK JEFF is infamous around these partsBLACK JEFF is infamous around these partsBLACK JEFF is infamous around these partsBLACK JEFF is infamous around these partsBLACK JEFF is infamous around these partsBLACK JEFF is infamous around these partsBLACK JEFF is infamous around these partsBLACK JEFF is infamous around these partsBLACK JEFF is infamous around these parts
Question tranny problems...need suggestions!!!!!
when car is turned off... i can go through all the gears with no problem with clutch pedal down or up.
when car is running... i can't go into any gear at all.
the only way i can drive is if i start the car while its in gear. when the car is trying to turn over the car starts to move even when clutch pedal is on floor. i can't take it out of gear once the car is running. so yesterday i had to start the car while it was in second gear and take a 15 minuted ride home in second the whole way.
i have a clutchmasters stage 3 clutch, limited slip diff., and autotech flywheel. all three have about 5000 miles on them. i need suggestions on what i should do here cause i'm puzzled.
Old Jan 17, 2004 | 03:52 AM
sk8rmike's Avatar
Bitches get Stitches
lol sounds like your pressure plate isnt disengaging the clutch from what you said but since im not familiar with Vdubs i would try bleeding the clutch system first....
Old Jan 17, 2004 | 04:19 AM
CHAHONDA's Avatar
corona connessuer
yes....bleed the system
Old Jan 17, 2004 | 05:35 AM
G60ING's Avatar
Corrado Butcher
G60ING is an unknown quantity at this point
I gave you reply on the tex if that doen't work guess its time to take few hours to pull the tranny for inspection
Old Jan 17, 2004 | 08:11 AM
nate95sir's Avatar
nate95sir is an unknown quantity at this point
that happened to my civic the exact same thing you described and i just had to get a new clutch put in.
Old Jan 17, 2004 | 10:13 AM
Stillpushin's Avatar
Blow Me
Stillpushin is an unknown quantity at this point
You should learn how shift without the clutch. I am not saying this to solve your problem but it definitly comes in handy.
Old Jan 17, 2004 | 02:25 PM
Rockybling's Avatar
LTDTEAM.COM
Rockybling can only hope to improve
he already did. replaced the slaved cylinder, and bled the system.
Old Jan 17, 2004 | 06:43 PM
BLACK JEFF's Avatar
McLovin
sorry guys, been at work all day today. yes i've bled the system and changed the slave cylinder on friday. but it is still doing the same thing. i was gonna change the clutch master cylinder also but i wanted to see what other peoples opinions were before i went and changed it. has anybody actually had a defective clutch b4? i mean i think i went like 1000-1500 miles on the breakin perioud of my engine/tranny. and i may have launched it maybe 2-3 times. i'm just tryin to narrow things down b4 i do the major thing and remove the tranny. thanks for the ideas guys...keep them coming.
maybe i am just that lucky to get a defective clutch
oh and g60ing i replied to your post on the vortex...http://forums.vwvortex.com/zerothread?id=1196270
tegman33
Dec 27, 2007 08:58 PM
CrJenkins13
Aug 16, 2007 05:48 AM
slipknot
Aug 29, 2006 04:44 AM
Ej8D16y8-T
Aug 30, 2005 04:34 PM
B16ASilverHonda
Jul 28, 2003 02:51 PM
