Tranny problems.....
Old Dec 11, 2006 | 06:05 PM
Slooby's Avatar
TAINT PUNCHER!
Default Tranny problems.....
As title states i'm having a little trouble with the tranny. I stated before that the clutch cable needed to be adjusted will it is and needs to be replaced. But the question is that going from 1st to 2nd it is kind of iffy in weather or not it wants to go in to gear. The original owner states that it could possibly be the cable and someone else says it could be the Syncs. (hopefully you know what i'm talking about i was about to attempt to try and spell it) Well i wanted some of your opinions as well. I plan on replacing the cable anyway. If it is the Syncs. should i just have it rebuilt, purchase a remanufactured tranny, or buy a decent used one from a salvage yard(if such thing exists) and have the one in my car built.
Thanks in advanced for any helpful information.
Old Dec 11, 2006 | 06:20 PM
Abysalone's Avatar
Fighterer
Abysalone will become famous soon enough
Default Re: Tranny problems.....
Next time your out try shifting clutchless from N to second. Give it a rev and try putting it in gear as the RPM's go DOWN. If your synchros are working correctly it shouldn't be too hard to put it into gear without much, if any grinding. I had an old 66' chevy with a Muncie RockCrusher that had a clutch go out and this got me around a few weeks. If your syncs are screwed it will just grind (as the truck later on did)
Weldmandingo
Nov 10, 2008 05:00 PM
tegman33
Dec 27, 2007 08:58 PM
FocusTunr
Oct 6, 2006 06:27 AM
Ej8D16y8-T
Aug 30, 2005 04:34 PM
B16ASilverHonda
Jul 28, 2003 02:51 PM
