Tranny problem
Old Nov 25, 2003 | 01:23 PM
gen4H22A's Avatar
BOXIN YOU
Default Tranny problem
I am beginning to have a pretty bad tranny problem....it used to be that she would grind in 3rd and 5th gear, Now, it will hardly let me put it in 5th gear, i usually cant, and on some occasions, the shifter itself will slip out of 5th gear...Now, it is starting to not let me go from neutral to 4th...or neutral to 3rd....is this the synchros that are being worn out? I checked all my fluids and it seems fine....and if it is the synchros, does anyone know a good place that sells trannys for decent prices???
PS... my car is a 95 Prelude vtec
Old Nov 25, 2003 | 01:48 PM
ZeroMR's Avatar
I'm still slow.....
ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR
i know that when had tranny problems i coundn't put it in 2nd, turned out it was my clutch. but don't know if thats your prob.
Old Nov 25, 2003 | 02:14 PM
Nato76's Avatar
The Comeback Kid
Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76 Nato76
It might be the clutch
Old Nov 25, 2003 | 04:44 PM
gen4H22A's Avatar
BOXIN YOU
it was just replaced about 200 miles ago.... unless it was faulty i dont think it should, but....after running my engine hard, i always smell clutch, evenm if i dont ride it or anything....it just constantly smells like clutch
Old Nov 26, 2003 | 12:26 AM
mysiqu's Avatar
mysiqu is an unknown quantity at this point
if its a b series tranny then yeah it happens.. use a stuff call GM Synchrosmesh, after about 500 miles it shuold fix the problem if not makes it alot better, well also unless you want to buy a new tranny, or maybe you don't know how to drive, but if you want a new tranny jsut hit me up, also if you want it installed just hit me up with some$
Old Nov 26, 2003 | 01:52 PM
gen4H22A's Avatar
BOXIN YOU
Trust me, i know how to drive, and its an H series engine...so id need that tranny, if u have one then let me know...
Old Nov 27, 2003 | 07:30 PM
Dethred's Avatar
Dethred is an unknown quantity at this point
If it breaks go here for your new one: http://levelten.com/
Nate29
Feb 15, 2009 03:09 PM
talonman
Oct 30, 2008 06:58 AM
LsVtecT96
Dec 11, 2006 02:48 PM
Tiny Tim
Jun 4, 2004 05:31 AM
RACER X
Apr 10, 2004 07:49 PM
