Toyotas arent dependable lulz
Old Sep 9, 2009 | 11:08 AM
  #21
Dubee88's Avatar
TonzAGunz
Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88
Default Re: Toyotas arent dependable lulz
amp fuse under the hood? if its melted and blown than you have some electrical issues going on...like perhamps amp wire guage too small for a fuse thats too large.
Old Sep 9, 2009 | 11:42 AM
  #22
dru's Avatar
dru
GUIBO!?
dru dru dru dru dru dru dru dru dru dru dru
if the amp wire is too small then the wire would fry not the fuse.. i think? haha..
which fuse? the inline power one? or the one on the amp itself.
Old Sep 9, 2009 | 12:04 PM
  #23
rexrunner's Avatar
rexrunner rexrunner rexrunner
Originally Posted by Dubee88
10 mm socket takes care of it once you get the radio bezel out of the way. check the fuse on the back of the radio, right by the radio plug. only other thing it could be would be a fuse in the car or by some freak chance there was a voltage spike that fubar'd the radio. That last one is not very likely.
A 10mm and a 14mm will pull apart an entire yota
Old Sep 9, 2009 | 12:43 PM
  #24
Dubee88's Avatar
TonzAGunz
true story
and as far as the amp wire melting...if you have a 100 amp fuse on 8 ga power wire I have seen the fuse block will melt because of the heat of too much current running through too small of a wire...think about drinking through a coffee stir or through a regular straw
Old Sep 9, 2009 | 01:20 PM
  #25
ShawnD's Avatar
Troll & Run
The fuse that was in the actual amp. I looked at it when I got it and it looked fine. Maybe it just got to hot back there for it. I +rep'd everyone that helped btw
Old Sep 9, 2009 | 05:28 PM
  #26
dru's Avatar
dru
GUIBO!?
^Look up the amp manual/specs and make sure you have the right fuse in there. Sometimes people like to just throw in random fuses when they pop.
Old Sep 9, 2009 | 05:30 PM
  #27
ShawnD's Avatar
Troll & Run
On the amp where the fuse goes it says 40a so I put in another 40a, but I'll look it up or try to. I bought it slightly used from a guy up here awhile ago lol
Old Sep 9, 2009 | 05:40 PM
  #28
dru's Avatar
dru
GUIBO!?
man thats convenient.. and its probably 99.9999999999% right..
everything should be fine now then, lmao
oh ya, make sure the inline fuse is rated according to the power cable. Not your power/current goals necessarily.
Old Sep 9, 2009 | 06:32 PM
  #29
ShawnD's Avatar
Troll & Run
Well I had a well known shop do the sup/amp install, hopefully they got it right lol
Old Sep 11, 2009 | 09:32 AM
  #30
Dubee88's Avatar
TonzAGunz
yeah if it was the fuse on the amp then disregard the inline fuse comments...hope its working now
chetchup
Aug 20, 2009 07:55 PM
