Civic problem need a little help
Old Sep 5, 2009 | 04:19 PM
NDThaBalla's Avatar
DOCH Nissan SLEEEEPR
NDThaBalla has disabled reputation
Unhappy Civic problem need a little help
Just put a D15 in my car motor SOUNDS good but there is SOOOO much smoke coming from the exhaust. Wondering what could be the problem.
My mechanic said most likely a head gasket.. but i would like to know what you all think as well. Also there is a tiny bit of smoke from the headers, nothing I believe is serious.
There aren't any problems with the exhaust as I got those problems fixed.
Thanks in advance.
Old Sep 5, 2009 | 04:21 PM
VB2NER's Avatar
has a huge dong
Default Re: Civic problem need a little help
color of said smoke?
Old Sep 5, 2009 | 05:49 PM
NDThaBalla's Avatar
just white smokey smoke
Old Sep 5, 2009 | 06:56 PM
jdmEF9_244's Avatar
jdmEF9_244 has disabled reputation
Oil ring problem
Old Sep 6, 2009 | 05:01 AM
1rude2l's Avatar
head gasket. its burning coolant. head or block could be warped or cracked also
Old Sep 6, 2009 | 12:01 PM
NDThaBalla's Avatar
how would be able to fix the warped head. replace it? If its cracked that sounds like I will HAVE to replace it
Old Sep 6, 2009 | 12:51 PM
Cyanide Jello's Avatar
Zerofucksgiven
Recommend a compression test and leak down test to narrow problems...
Old Sep 8, 2009 | 03:38 PM
NDThaBalla's Avatar
Will the engine light be on if the block or head is warped or cracked???
Old Sep 10, 2009 | 05:47 PM
NDThaBalla's Avatar
Old Sep 10, 2009 | 05:50 PM
j4k3's Avatar
holla
Probably a head gasket seeing as the smoke is white. Why not swap to a better motor than the D15?
