Synthetic Oil
1. No I havnt had any negative experiences.
2. Stick to Mobil one synthetic.
3. Yes, you CAN mix regular and synthetic.
4. Yes, you can go longer between oil changes. I still change mine at 3-5k to be safe, depending on what sort of driving my car see's during those miles.
-Mike
-Mike
to me this sounds like alot of opinions and garage science put together through personal experience. if you really want to know i recommend Emailing some of the motor-oil companies for the facts on the products. Most are more than happy to give you the right info you need. I use Quakerstate Sythetic in my honda, for the first 2k i noticed improved gas milage just by 2-3... probably because the other oil was very very old.
blends ARE about 10% synthetic across the board! AmsOil has the best specs regarding heat. Mobil1 has the best flow rate out of syth oils. Redline has best detergent qualities. i believe (if memory serves me right) the same in conventional oil goes like Castrol GTX, Pennzoil, Kendal GT1.
word to the wise, though! there are other mitigating circumstances such as ash and antimony content that i did NOT tally-in.
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
haha the only reason i bought the brand I did was because i saw quakerstate's commerical about how they got a 10% friction decrease and that the teams they sponsor in nascar use the same oil. i thought if its good enough for nascar engines, its good enough for my honda!
If your car burns oil....(they all do to some degree or another) dino oil will lower the octane rateing of the fuel/air charge...
synthetic will not..
having said that, it is my expirence (I used both in the teg extensively) that you will burn about twice as much synthetic..
