Suspension and brake project
RandomTask had it right....
When you are bleeding the system, start with the wheel that is farthest away from the master cylinder, and then work your way back towards the front left wheel. In other words bleed the system in this order: right-rear, left-rear, right-front, left-front. Bleeding in this order will minimize the amount of air that gets into the system.
use air tools. save your self a few years.
the lower ball joint is removed easiest with a pitman arm puller from advance auto. it fits the arms perfectly over the top of the lower control arm and the bolt center in the stud of the ball joint, be sure to give the side of the control arm a few extremely hard hits with a 10lb hammer before hand to loosen things up a bit. here is the link to the one i use every time.
http://www.partsamerica.com/ProductD...tnumber=T72069
the notch on the axle and the nut is refered to as a "stake", saying that you stake the nut once its properly tightened on the axle to keep if from backing off.
