Stuck Axle Nut
RIP MEAST
Stuck Axle Nut
Im pulling out my motor. Everything is done except for the passenger side suspension adn thats because i can not get this axle nut off. Ive tried heating the bolt, hitting it with an impact gun, breaker bar. The fucker wont come off. Any ideas?
Re: Stuck Axle Nut
Originally Posted by bigd0915
maybe you can use a sawzall or dremel and cut the nut in half?
or use some pb blaster and a breakerbar with a big ass piece of steel pipe for leverage.
edit: and my next step would probably be getting a cut off wheel and cutting the damn thing off.
Awesome.
Re: Stuck Axle Nut
Originally Posted by sk8rmike
acetylene torch, cut it off but just be careful not to damage the axle...unless you dont give a fuck about it at which point blast away.
The Pro to call.
Re: Stuck Axle Nut
i have never met an axle nut i couldnt break loose.
IR titanium impact with 1000ftlbs tq in reverse. if that dont get it....my 3/4 drive will.
you are doing lefty loosey, right?
yes, but unless you are good with a torch, you run the risk of damaging the hub bearing. or the hub.
it is a skill to be able to remove a nut from a bolt, leaving all of the threads, using nothing more then the good ole blue tipped wrench.
